Home>Forums>Site Polls>Paint finishes Search Within This Topic
Poll Question : What type of paint do you prefer to use?
78 [ 12.89% ]
76 [ 12.56% ]
127 [ 20.99% ]
147 [ 24.30% ]
133 [ 21.98% ]
44 [ 7.27% ]
You can not vote in this poll
Posted: July/14/2006 at 10:24am  Quote
What type of paint do you prefer to use and why?
Avatar User Offline sevarg
Passed Away 2016
Posted: July/14/2006 at 10:43am  Quote
I much prefer polyurethane based paints such as the old Chevron Perfect Paint brand.
  1. Easy to spray.
  2. Flows out evenly.
  3. Thins and cleans up with mineral spirits.
  4. Not as toxic and nasty as automotive paints.
  5. Surface is impervious to just about every thing. You can even clean off spilled CA by using straight nitro methane without damaging the surface.
  6. Removal is easy with a water based paint stripper for repair work.
  7. Compatible with most other paints if you find it necessary to mix types of paints.
BUSA 1/3 Pup
GeeBee Sportster
Canadair 215 Water Bomber
BUSA 1/3 Nieuport 28
Thomas repair:1/4 Beech Starship
Repairing: 40% Cessna U3-B
Building:Kawasaki Ki-100 110"
NEXT:NorthropXB35
Avatar User Offline don
Posted: July/14/2006 at 11:06am  Quote
Most of my painted planes are of the civilian types and shiny, so I prefer auto catalyzed paints but It does get little pricey if your doing multiple colors.
Major glue waster
Avatar User Offline Boomerang
Posted: July/14/2006 at 5:51pm  Quote
I voted multiple types.  My current favourite method uses grey car type primer followed by cellulose car colour  or enamels, either Humbol (lots of colours) or household from the spray can or mixed from tins.  I usually clear coat in one part polyurethane to even out the different gloss levels & to fuelproof. - John.
Current Project Aermacchi MB 339.
Avatar User Offline Doug B
Posted: July/18/2006 at 2:18am  Quote
I have switched over to latex paints from automotive paints because of cost, fumes [neighbors complaint].May be a bit slower in drying times. After painting a camoflauge scheme I spray with a water based satin finish polyueathane
Avatar User Offline AndyMc
Posted: October/25/2006 at 11:24pm  Quote
Bunga
How is the fuel proofing against nitro with the water based poly.  I have used oil based wattyl etc but it does yellow light colours.  What brand have you used.
regards Andy
Posted: October/26/2006 at 3:18am  Quote
   Hi Andy,
    As of yet I have not tried any of the water-based clear with nitro  but I do know that it does not affect standard glow fuel or petrol fuel.
The brand I use is COBOTTS CRYSTAL CLEAR and it does not turn yellow. You can spray it on with hardly any thinning as it is very thin in the tin.
Dont be fooled by the bluish tinge as it dries clear. Comes in Satin,Semi-gloss and Gloss.
Hope this is a help to you.
Bunga
Avatar User Offline Steve_O
Posted: November/22/2006 at 3:46pm  Quote
Is Chevron Perfect paint still available?
Point Hinges
Aging a finish
Paint types
Paint Masks
