Home>Forums>Show Your Stuff!!!>Hinges Riveting Search Within This Topic
Avatar User Offline Corsair1964
Posted: March/22/2015 at 9:27pm  Quote
Hi All
Here is a link to photos for hinges and a tool I found for riveting , works very well, you will see link to the photos
Photos
https://picasaweb.google.com/Flightplanrc/TipsAndTricks#
Riveting tool link
http://www.craftedfindings.com/rivetinginfo.html
Note I did have to make an  adjustment to the flap removing the rivet was easy just used a diamond ball end bit on a dermal and ground the pressed side of the rivet , removed the rivet , placing the new rivet in was a little more trick , but basically used the one end of the tool see photo's .
Have a good flight, 60 thousand and climbing
https://goo.gl/photos/N9awzz6wVnRkiUhw7
Riveting
Wing Sheeting
Wing Sheeting
Timing is everything
