Gtarling Basic Member
Joined: June/10/2007 United Kingdom Posts: 320 IP Logged
Posted: May/24/2014 at 8:40am |
A couple of pics of my recently completed 1/3 scale SG-38 glider. Built from a free plan on the scale soaring UK site, I had a set of wing ribs laser cut and built most of the rest from scratch. Pilot and radio gear were bought items. It spans 3.5 metres and weighs approximately 19 pounds when the optional power pod is fitted. Approximately 16 pounds without the pod and battery. The power pod was only built as a means to get the model airborne when there's not a suitable tug available. It has had one flight using the power pod, but has yet to be aerotowed. It flew superbly and needed no trimming at all, which was a huge relief to me! Various decals and placards have been added since these pics were taken and I need to fabricate a plywood wing centre section fairing when I can think of a way to attach it.
windnwires Lifetime Site Supporter
Build observer
Joined: November/30/2005 United States Posts: 263 IP Logged
Posted: May/24/2014 at 5:29pm |
Very Nice scale build there Gordon Looks Sweet in the air!
Jim
ARUP Lifetime Site Supporter
Joined: December/10/2009 United States Posts: 1600 IP Logged
Posted: May/24/2014 at 8:26pm |
Nice! The pilot 'slaves' from control inputs, correct?
Posted: May/25/2014 at 2:40am |
Thanks for the compliments chaps!
Michael - the pilot's feet are fixed to the rudder pedals, which move with the rudder. The joystick moves fore/aft with elevator input, but the pilot's arm restricts the movement too much when his hand is holding the joystick, so he currently flies 'hands off'. I'm working on improving things in that area! Joystick movement with aileron input wouldn't have been practicable to do while still having the wings readily detachable.
vik_ Basic Member
none
Joined: September/11/2003 Czech Republic Posts: 371 IP Logged
Posted: May/25/2014 at 2:57pm |
Great looking sail plane. What power it has? And the plan is from scalesoaring.co.uk? Regards Viktor
Posted: May/26/2014 at 2:54am |
Viktor - Thanks. Power is a cheap Turnigy motor running on 4S with a 17 x 10 prop, giving around 1000 Watts. I can check the motor number later if you need to know. Yes, plan was on scalesoaring.co.uk, but I just looked for it and can't find it now.
vik_ Basic Member
none
Posted: May/27/2014 at 12:09am |
There is now only 1:5 version Any chance you can share it with me? I would like to build one maybe next winter. Thank you
Posted: May/27/2014 at 12:24pm |
Vik - I don't have the 1/3 scale plan in electronic form. Cliff Evans supplied me with a print at 1/3 scale and I think he may have just scaled up that 1/5 version. You can contact him via the link here - http://www.tvsa.scalesoaring.co.uk/VINTAGE/Plans/CNC/CNC.htm l
