Home>Forums>Introduce Yourself>New Member with Large CNC Router for Foam Search Within This Topic
Avatar User Offline PhantomGhost
Posted: March/12/2020 at 2:48pm  Quote
Hello,
I'm looking to mill some foam parts!
one of my current interest is automated flight with surveillance, which is what brings me here. I'm looking to mill some plugs for aircraft and maybe this interests a member who could benefit from my services. I'm currently looking for projects to build my portfolio.
Check out the video using only 2lb density foam...I get a good finish and smooth to the touch.
youtube video
I have epoxy tooling paste as well, which is similar to bondo. Leaves a really good finish, but dulls the bit and is excessively dusty and stinky. I can supply plugs/prototypes unfinished as in the video, or they can be finished in a coating of your choice.
I have experience with building prepreg carbon fiber parts for an OEM auto supplier, and hope to be producing parts in the next few months. I have a 3D scanner handy. Maybe you have something in mind, don't hesitate to bounce ideas off of me. Scale models? Sure. My cutting envelope is 80"x60"x20". My business address is located in Raleigh, NC. You're more than welcome to stop by
thanks for reading
Ron
Posted: March/12/2020 at 3:31pm  Quote
Ron,
Ever work with 60 to 100 density High Load Styrofoam?
Posted: March/12/2020 at 3:45pm  Quote
Are you referring to pink XPS or insulation foam?  If so, yes.  It melts at the speed that I mill...I max my machine at about 120 in per min for the 2lb EPS.  Why do you ask?
Posted: March/12/2020 at 4:04pm  Quote
60/100 High Load Dow Styrofoam is blue XPS.
Posted: March/12/2020 at 4:06pm  Quote
You must be looking to make beyond line of sight UAS.
Posted: March/12/2020 at 4:26pm  Quote
I'm sure that I could mill it just fine if that's what someone requires.  Yes, I have an idea...nothing that hasn't been done before.
Posted: March/12/2020 at 4:28pm  Quote
Care to share?
Posted: March/12/2020 at 6:43pm  Quote
Ummm..nothing to share, really.  I like the Parrot Disco with the 4G hack.
New Member with varied experience
New Member from Southern WI
New member from the Netherlands
November Site Supporter Download
