Home>Forums>Show Your Stuff!!!>Carb DA 50 or any carb Search Within This Topic
Avatar User Offline Corsair1964
Posted: August/24/2018 at 7:18pm  Quote
Hi
I have been flying P47 Thunderbold a lot of years , every year after the second year of flying the mixture change overtime of each summer what I finally notice was that the carb bolts came loose , after an engine failure and a successful dead stick I decided to figure out the issue and stop it from happening. Wish DA had this simple solution from the get go . Wire the bolts-attached is a picture .
Have a good flight, 60 thousand and climbing
https://goo.gl/photos/N9awzz6wVnRkiUhw7
Avatar User Offline moggy
Posted: August/24/2018 at 7:47pm  Quote
Have you tried Teflon tape on the threads?
In the hangar: 2 YA Spitfires,
Giant Stinger.Building: Ziroli Spitfire. In the Que: BT Spitfire MK V
"You can teach monkey's to fly better than that."
Posted: August/24/2018 at 9:25pm  Quote
Clean bolts and holes with acetone and use blue Loc-Tite.... and since you have the holes drilled go ahead and add safey wire.
Belt and suspenders
Avatar User Offline kuhn
National Flag of Bulgaria Bulgaria
Posted: August/25/2018 at 2:10am  Quote
Line the holes you drilled in the red bolts up and push a sturdy wire right through both and bend the ends a bit.
Simple and secure.
No it wont make a difference to the air sucked in.
Kuhn
If in doubt. Don't!
Flying: HIGH!
Building: Getting my Mo Jo back slowly to finish a few projects.
Carbon Fibre Tube for Landing Gear
Hangar 9 .50 Corsair
Carf Mig 15 or others
newby to the forums and club
